AC Condensate Venturi style drain
Has anyone made or do you know of the fitting that connects to your AC water circulation "out" / "Overboard" for the drain pan on the AC unit?
Hard time finding one, Marvair makes one for the low, low price of $339 dollars. https://www.defender.com/product.jsp?id=2756613 Last piece of my puzzle so that I can wrap up my AC install. |
Originally Posted by frickstyle
(Post 4828227)
https://www.supplyhouse.com/Raven-MF...X-Monoflow-Tee
The ac drain would go in the 1/2'' branch the return arrow would point overboard |
So your condensation will theoretically not be going into your bilge then Justin??? Good idea!!!!
I may need one of those too. |
I put that type of device on my Outlaw years ago (20ish). I am wanting to say it was called "condensater" at the time and not overly expensive. It worked as advertised as well. May have been from "Mermaid Air".?
Mark |
A 500gph (1.8m3/hr) HVAC water pump will dictate a 3/4" plastic Chinese venturi injector. See link below. You may or may not need to play with the check valve spring.
Fertilizer Injector, Venturi Garden Irrigation Device Kit, G3/4 Fertilizer Injector Switch Water Tube Kit |
I just had a customer call me about this very issue. Their pump was the issue in this case but he told me about this:
https://www.mmair.com/marine-divisio...d-condensator/ |
I just plumbed this into the condensate pan, and T-Ed it into the overboard discharge hose. Works GREAT. never a drop in the pan….. got so tired of the condensate ending up in the bilge….
https://cimg1.ibsrv.net/gimg/www.off...aeba61e0b1.png |
Originally Posted by Wally
(Post 4831265)
https://www.mmair.com/marine-divisio...d-condensator/ Sooooo, after hours (days) of searching and dicking around, I broke down and bought this setup. It was $250, but I felt between buying fittings, testing, and the time I had spent searching for a solution - I cut my losses and bought the above kit. It was a pretty simple install once you figure out how to route everything. That AC project kinda took me through the ringer a bit, but I finished it last Sunday. |
| All times are GMT -5. The time now is 11:35 PM. |
