Advice on Building an Engine, overseas
Subscribe
05-10-2022 | 01:01 PM
Cris craft stinger 22ft....that is my boat
Reply 2
05-10-2022 | 01:26 PM
I doubt Dyno facilities are common there. Try to get a carburetor that’s as set up as possible. Maybe pay to have one that’s been dyno tested and set up on a very similar engine to yours shipped over.
Reply 1
05-10-2022 | 01:36 PM
Yea...your right about dyno...there are no engines like my...the best we have are mercrusers 5.7...6.2....and 7.4...that is in liters we are in metrick sistem.So i dont have spare parts everything i need i have to order from USA and wait for 20 days to come..wery expencive...I have found a carb it is a 750 i think it has 2 acc pumps and 2 floats holly and im making a blowthrou aut of him.
Reply 0
05-10-2022 | 02:53 PM
Quote: Yea...your right about dyno...there are no engines like my...the best we have are mercrusers 5.7...6.2....and 7.4...that is in liters we are in metrick sistem.So i dont have spare parts everything i need i have to order from USA and wait for 20 days to come..wery expencive...I have found a carb it is a 750 i think it has 2 acc pumps and 2 floats holly and im making a blowthrou aut of him.
Id recommend buying one setup to be a blow through carb from CSU or someone like that. It would be cheap insurance. Your science experiment carburetor could blow up your whole engine. Try to copy a proven engine combination as much as possible
Reply 0
05-10-2022 | 03:57 PM
Quote: Hi guys...my name is zole and im writing you from another continent...I have a chevy 502 big block with a holly 750 blowthrou carb with a m-1 procharger and a water coold inzercooler.It is a stock engine and it is going in a cris craft boat.Since nobody in europa does this kind of engines i decided to ask for help from you guys...Before I start sending spec is there sombody who is willing to help me make this engine run.I come from croatia a small country across italy
.thank you in advance and excuse my gramar
I run a blow through carb set up and if you don't have access to a dyno at least get a wide band o2 set up it will make adjusting the carb a little less difficult
Reply 0
05-10-2022 | 09:32 PM
Thanks guys for the tips...A videband a/f guage is coming with the parts for the carb and a set of holly jets 64-99...
Reply 0
05-10-2022 | 10:33 PM
Watched Engine Masters on TV (cable - motortrend channel) the other night, the episode they tested different blow thru carb hats and different positions of the hats with 8 02 sensors (1 per cylinder) and all i can say is yikes ! Oh, and try go find it on youtube or etc.
Believe episode is ‘ Carb Hats for Blowers ‘
Reply 2
05-11-2022 | 04:50 AM
Thanks for the info...ill take a look.But honestly i think with the help of you guys i could make this work.I'm not looking for big boost since my engine is all stock max that i would do is mayby 4psi nothing over that.
Reply 0
05-25-2022 | 10:31 AM
Quote: Thanks for the info...ill take a look.But honestly i think with the help of you guys i could make this work.I'm not looking for big boost since my engine is all stock max that i would do is mayby 4psi nothing over that.
This is the carb i need help with...got the holly blowthrou set few days ago...im starting modification soon.
I realy hope we can make this work
Reply 0
05-25-2022 | 11:51 AM
Can sombody tell me the best way to set valve clerance on this engine.
Reply 0
