-   -   Carb in a box question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/375900-carb-box-question.html)
Zole 05-31-2022 03:55 AM
https://cimg1.ibsrv.net/gimg/www.off...e4a6027326.jpg
This is the carb i got whit the engine..im missing the uper part of the box...can sombody tell me is this the right carb.the nubers on the coak horn are 80486...and1085..thank you guys
Bondo 05-31-2022 06:23 AM
Ayuh,.... No idea what yer motor, 'n drive are, so no idea if it's the right carb,....
The box is for a turbocharged blow-thru application,....
So, if you don't have forced induction, you don't need the box,....
Zole 05-31-2022 07:17 AM
https://cimg0.ibsrv.net/gimg/www.off...169d49356c.jpg
502 cheavy all stock.with a m-1 procharger kit..
larose481 06-04-2022 07:56 AM
I'd check the list number again on the choke horn. On marine carbs it will be that 5 digit number but you must be a digit off cause that number doesnt exist.
green lightning 06-04-2022 09:13 AM
It should work if it is bigger than 700 cfm I could not find a listing for it just keep a eye on your air fuel ratio numbers how are you altering your fuel pressure under boost.
Griff 06-04-2022 09:31 PM
That looks like its a carb off of an HP500. 800cfm 9022 carb
Zole 06-05-2022 03:05 AM
i'll whatc aut for that...thank you
Zole 06-05-2022 03:42 AM
https://cimg8.ibsrv.net/gimg/www.off...b2381ab254.jpg
Here is my chocke horn if you magnifie you'l see the nubers...thank you
green lightning 06-06-2022 12:05 PM
Does that fuel pump generate enough pressure to be used under boost conditions
Zole 06-07-2022 12:10 AM
fuel pump makes 9 psi and my boost is going to be around 5 psi
