New flooring for 28 pantera question
You can’t put the marine mat/sea deck over the coin floor. Coin floor (I was told it was called pereli flooring) needs to be ripped up and any extra adhesive removed. I had to sand mine and refinish. Then the new floor can go down
sonicss42 (07-04-2022)
Rephrase - Marine Mat/sea deck can be put over anything. If you want it to last long and look good I would recommend tearing out the existing floor. Otherwise you will end up with the above picture.
A friend has Seadek type flooring laid over his lonseal and has no issues. This is the 3rd season for it. They did dye/paint the edges of the lonseal to closely match the base layer color of the seadek
87MirageIntruder (07-19-2022)
