Pulling the motor.
Old 04-19-2023 | 10:00 PM
Originally Posted by speicher lane
OP, Yu may have already covered it in a posting, but if the engine inhaled water, did you at least flood the cylinders to stop the corrosion ( its been a while since the thread started)?.... or are you going full rebuild?
back. Wife is doing better, but not out of the woods. Progress with her is slow. It’s been 7 months of treatment, likely need another 6 months. Ice is coming the reservoir, time to get back to the build. Yes I did flood the cylinders. Still have the motor sitting in my garage on the engine stand. Handy move sine I last posted. It’s listed here locally for sale. No takers yet. Probably, finish the 496 stroker then go through the old 454.
Batmeat is offline
Old 04-22-2023 | 05:17 PM
Back to working on the 496.
Gota get pushrods. Somewhere around 8-10 inches
Batmeat is offline
Old 04-22-2023 | 06:20 PM
Is that a steel freeze plug?
xlint89 is offline
Old 04-22-2023 | 06:22 PM
its the back of the camshaft journal,,its always steel.
sutphen 30 is offline
Old 04-22-2023 | 07:34 PM
correct
Batmeat is offline
Old 04-30-2023 | 04:23 PM
Latest update… bought another engine stand. Swapping the old motor over to it(still trying to sell it.$3500 too much for it? Rebuilt with only 40hrs). Time to put on the remaining accessories, wire it up, start it, the put it back I to the hull.
Batmeat is offline
Old 04-30-2023 | 05:01 PM
F-2 Speedy's Avatar
are those flat tappet lifters, are using an adjustable push rod to get the geometry correct for length
F-2 Speedy is online now
Old 04-30-2023 | 06:38 PM
yes and yes. I have adjustable pushrods to measure length.
Batmeat is offline
Old 05-08-2023 | 06:05 PM
Pushrods are ordered. Talked to Matt at Manton Pushrods. Cool guy and super helpful. 8.35 on the intake, and 9.31 on the exhaust side. 3/8 by .145 thickness.
Batmeat is offline
Old 05-22-2023 | 04:43 PM
Pushrods and Y pipe exhaust block plate are here. Can finally finish building the motor!
Batmeat is offline
