cannot find 3/8 thru hull fittings? >
Old 06-20-2023 | 01:52 PM
Default cannot find 3/8 thru hull fittings?
Where can I find the 3/8 barb thru hull fittings in white plastic? replacing all mine and can not for the life of me find a replacement- option 2 is just get 2 nuts and double nut the old ones that lost the outside heads.. thread is m12 fwiw- can just get 2 nylon nuts, but not sure if i have enough left to go thru hull with nut on both sides..
CamaroMan is offline
Old 06-20-2023 | 11:16 PM
Rookie's Avatar
A picture is worth 1000 words.
Rookie is offline
Old 06-20-2023 | 11:51 PM
SB
SeaChoice thru hulls found at most places, even local hardware stores here.
SB is offline
Old 06-21-2023 | 12:34 AM
well i can find any size 1/2 up - nothing for 3/8...
Old 06-21-2023 | 04:28 AM
SB
My bad, my dimly lit brain read different than the 3/8 you typed.
SB is offline
Old 06-21-2023 | 05:32 AM
Well here’s a 1/2”. There’s all kinds around here. I had a hard time not finding white plastic. But I always use the biggest thing I can for volume. If u can’t find the perfect thing. I’d run hose from whatever to size splice to what’s close.
Five Oceans White Straight Thru-Hull Connection for Hose https://a.co/d/4vHzVNL
Xcomunic8d is offline
