Bore and stroke?
Thinking about pulling this apart again before spring.
Did a basic rebuild about 4 years ago and only put about 20 hours on it It's a 454 Magnum, .030 over with speed-pro pistons. 088 heads, Crane 731.
One piston was showing some detonation. Machine shop cleaned it up and said run it. Was trying to keep a tight budget. Heads needed rebuild so they did get all new hardware, guides and Ferrera valves, Merc roller rockers.
Well now this is always on my mind and thinking to go back in, go .060 over and maybe stroke it while I'm in there.
Thoughts? Should I just do bottom end stock and spend some money on heads?
What are your goals/targets, if any? In my humble opinion, and past automotive experience, 'stroking' an engine tends to have minimal gains for the effort and cost. But there are far more experienced members here that hopefully will chime in.
Baja 252 Islander
Baja 252 Islander
Today’s stroker kits are very reasonable. Sure it’s not difficult to get 475/500 hp without going crazy on a 454/468 but 496 is easier to obtain with near the same components plus an additional 50 plus hp. As mentioned all depends on what your end goals are. Should be approx 4 mph depending on hull efficiency etc etc.
Like the old saying goes there’s no replacement for displacement!
