-   -   Bubbles in cooling? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/383631-bubbles-cooling.html)
Ville123 09-08-2024 02:22 PM
Bubbles in cooling?
Hi,
I have a situation where I have bubbles in two raw water cooled 1987 merc 260 engines between thermostat and manifold. The water coming in is clear (bigger hose on video).
At idle water is clear, bubbles appear at about 2000RPM
Both engines are recently rebuilt, with heads done, new head gaskets, new piston rings etc. Engines have also new thermostats, one has new circulating pump. There are no visible leaks anywhere. The oil is not emulsified and clear. There was an issue with one engine not exactly overheating, but heating up faster than the other. That made me investigate, and I found the bubbles. Then I checked the other one, and bubbles too.
Merc repair manual states that bubbles at higher RPM indicate a blown head gasket. I presume can also a head crack. But, since everything is new - can it be something else? An assembly issue?
Here is the video, both engines are approximately the same.
https://www.dropbox.com/scl/fi/i6kx7...=8zj09g0x&dl=0
Thanks,
Ville
Ville123 09-09-2024 07:37 AM
I tried to do an automotive CO2 test, where gasses from exhaust go through a dyed liquid that changes color, no result.
Since raw water cooling does not have an expansion tank, so I could not accumulate the gasses - so I tried just by making a tee between thermostat housing and manifold with a hose high enough so that water would not arise to the top and put the tester on top of it. Air bubbled through the test kit, but it did not change color.
I am not entirely sure if an automotive test could be applied to this situation. Does anyone have any idea or experience?
https://cimg3.ibsrv.net/gimg/www.off...21f9e67fd9.png
mrv8outboard 09-09-2024 09:26 AM
I have seen small block head where the water jacket rusts out too close the the flame ring area of the head gasket creating a compression leak.
Ville123 09-10-2024 07:33 AM
Hi, yeah I had that. But as I said the heads are rebuilt, the one with rust is new. So this is not the problem.
My main question is - can these bubbles be something else than exhaust in cooling. If there is anything to rule out before pulling the heads, I would do that.
Thanks,
Ville
BillK 09-10-2024 06:15 PM
Where are you doing the CO test in the picture ? At the thermostat housing ?
Ville123 09-11-2024 01:22 AM
Yes
BillK 09-11-2024 08:54 AM
Originally Posted by Ville123 (Post 4908440)
Yes
If it was a head gasket it would show up there. Are you sure you are not chasing a problem that doesnt exist ? I have never seen clear hoses like that and have to wonder if the small bubbles aren't normal. Especially where both engines have them.
Tartilla 09-11-2024 09:50 AM
Typically when speaking to bubbles in the coolant...it mean percolating in a closed cooling system at the coolant inlet/catch can.
Water agitation can create some bubbles. Just look at what the prop does to the water. Well after contact.
+1 ensure you're not chasing an issue that is not an issue.
Ville123 09-11-2024 12:58 PM
Hi, thanks guys for thinking along. Actually to make sure that I am not chasing a non-issue, I actually wrote here.
Originally I started chasing the issue because it seemed like one engine was overheating, later I found out that it was a faulty sensor.
But, where I got the theory:
I found a thread https://formulaboatsforum.com/VBFORU...manifold.9835/
Where there are two videos - a problematic one with blown head gasket:
And a good one:
Also mercruiser manual states:
https://cimg8.ibsrv.net/gimg/www.off...8cdf51837c.png
So all this led me to think that I have a problem. But since no other symptoms are there... i was not sure, thereby wrote here :)
Thanks,
Ville
TomZ 09-11-2024 01:33 PM
Is it overheating? Any signs of water in the oil?
The example you gave shows pulsing that I would guess is more indicative of a failed head gasket (or other leak). With yours being steady and fine, it could be as simple as the turbulence caused by the water pump or something to do with the thermostat itself (aeration).
I have seen the identical temp senders give different results. Have you checked temperature with an infrared thermometer? A compression test could be useful, too.
Ville123 09-11-2024 01:45 PM
Its not overheating, but it heats up quicker than the other engine. It seemed to overheat, but it was faulty sensor. But the quick heating is still strange.
Anyway, oil is clear. I actually started to suspect the thermostat myself. Its new, but the housing is quite corroded.
There is one more strange symptom, the engines sometimes flood when idling in gear after a hard drive. This is as strange as it seems, caused by excessive blowby. When crankcase vents are disconnected then it does not happen.
The engines are rebuilt, new piston rings etc. So... maybe I am a little overcautious when believing that there is no issue, because I have had a horrible amount of issues. Most of them solved, but troubleshooting and fixing sloppy rebuilding has taken two years and the engines have come out repeatedly (oil pumps, camshafts, you name it).
Now the rest works - but these bubbles are a bit anomalous... so I´m cautious. Seems unrealistic that now it works ok :D
TomZ 09-11-2024 03:11 PM
Both engines have the bubbles, but only one heats up quicker? Perhaps just a slower thermostat?
Ville123 09-11-2024 03:20 PM
It is possible that the one that heats up slower, is leaking from side or a bit open.
