Dry exhaust water dumps
Old 05-26-2025 | 05:32 PM
Default Dry exhaust water dumps
Hello All,
I not sure what size hose is recommend for the exhaust dry pipe dumps. I need to buy some dump fitting just not sure if they should be 1 inch or 3/4 hose size to the dumps.
Jeff
Zinger is offline
Old 05-26-2025 | 06:36 PM
seafordguy's Avatar
I’m 90% sure mine are 1”. I can look tomorrow if you want me to.
seafordguy is offline
Old 05-27-2025 | 11:06 PM
I always thought 1" was standard, I've never seen 3/4" used for dumping
CheckmateScarab is offline
Old 07-25-2025 | 07:28 AM
nocigarette's Avatar
Doesn’t really matter what size depends on what it does to the water pressure.
nocigarette is offline
Old 07-25-2025 | 11:15 AM
1" Hose.
LSXCJ is offline
Old 07-25-2025 | 12:13 PM
Veteran: Army
Right. And if pressure drops too low, you can add restrictors to the through hull dump fittings.
DrFeelgood is offline
Old 07-27-2025 | 04:57 PM
what's the ideal water pressure?
Cole2534 is offline
Old 07-27-2025 | 05:33 PM
Veteran: Army
15-20 at cruise, maybe 25 @ WOT?
Old 07-28-2025 | 02:24 PM
25 at WOT is typically the maximum you want
Different setups will cause different pressures, ie transom pickup vs lower unit, crossover vs circulation pump
My old 525 manual stated 40psi is fine.. seems really high but what do I know!
Old 07-29-2025 | 07:39 PM
Hey Jeff,Most dry exhaust dump setups typically use 1-inch hose, but it can depend on your specific manifold or riser setup. If you’re unsure, check the OD of the dump fitting on the pipe, it’ll usually match up with the 1” hose. Some smaller systems use 3/4”, but 1” is more common for better flow and less backpressure.
Bira is offline
