TRS sloppy steering issue
My 1983 TRS drive has a lot of wobble. My gimbal is good but this bushing is really loose and I think it is to blame
What is this piece called and do I have to disassemble the whole steering system to fix it? https://cimg6.ibsrv.net/gimg/www.off...1777c6dba4.jpg |
Ayuh,..... That's not yer problem,..... That's the valve that tells the P/S system to push, or pull, 'n how hard too,.....
If there's no play there, the P/S system won't work,..... The slop you see with the motor off, goes away when the motor is running, making P/S pressure,.... |
Originally Posted by Bondo
(Post 4939426)
If there's no play there, the P/S system won't work,..... The slop you see with the motor off, goes away when the motor is running, making P/S pressure,.... That confirms what others have said as well. Great, because I now have one less thing to fix. Eventually I will get full hydraulic |
Convert to external hydraulic steering and be done with it. The stock TRS steering leaves a lot to be desired.
| All times are GMT -5. The time now is 09:14 PM. |
