-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   Donzi with the New Dana Exhaust (https://www.offshoreonly.com/forums/donzi/157243-donzi-new-dana-exhaust.html)
LAKESIDE RESTORATIONS 05-14-2007 07:01 AM
I try.. ;)
LAKESIDE RESTORATIONS 05-14-2007 07:03 AM
I try.. :D
dana marine products 05-16-2007 09:57 AM
Has the new prop come in yet? Just curious as to the results from your exhaust upgrade. Please keep me posted on the results.
LAKESIDE RESTORATIONS 05-16-2007 10:29 AM
Bob,
Yes they did get one prop size up from a 25 turbo to a 26 in a turbo prop eventhough I recommended a 27 mirage + from the get go with the new exhaust.. :D (but each owner does have their own prop preferences as you are probably aware) :).. It still spins the 26 very easily so we shall see wht the 27 will do.. They are supposed to try a 27 turbo this week.. I think that will be the ticket.. They noticed a good improvment in accelleration & it easily banged the revlimiter with the stock prop... :) They are quite happy overall with the power & perf increase.. Besides that the bling bling looks good in there.. :)
Jamie / Lakeside
Undertaker 05-21-2007 02:35 PM
Could not turn a 27P Turbo TXP the 26 Turbo TXP WILL be the Prop:D:D once some sensor issues are solved..... the mirage prop might be a fast prop but the handling of MY boat sucks with the mirage...all 22 classics run & handle different as we found out at AOTH in Kentucky...
Dana the prop issue is NOW solved lets see if Jaime can cure my sensor issue.....will keep you posted on that so you can pass along THAT info to your future customers BEFORE they purchase your exhaust..
Undertaker
dana marine products 05-21-2007 03:14 PM
Undertaker, I've spoken to Jaime on your situation and I'm very interested to hear the results of the beeping sensor.
If there is any problem that our exhaust is creating (water psi or temp), this will be the first time it has happened outside of our initial product testing.
We have roughly 50 sets out to date, 16 of which are local clients who have installed and ran with no issues what so ever. We've done 3 installations here with great results.
If I didn't have all these other systems out there running perfectly, I would be concerned that we may have some form of issue. I'm confident you'll find that this issue is an isolated issue with a difficult or defective sensor.
Run the boat with your 26, see the actual engine RPM's off the scan tool. If you're beeping the alarm, that means the engine is already retarding itself. It wouldn't surprise me if once the sensor issue is fixed, you'll probably get different results from your propellers.
If you need any assistance you can reach me @951-279-5005
ToTheMax 05-26-2007 05:31 PM
Sounds MUCH better than stock! :drink:
