Test result Formula,Fountain,Donzi why?
Best Quality?? I would say not...but Fountain is what it is; a great value. Most High end performance boats have gotten WAY overpriced, because they can. Fountain is fast for several reasons, but mostly because of their relentless R&D...testing each and every boat, AND most significantly, their size. They are low profile narrow boats. Their are many things I hate about Fountains(& a few I like), but they are a very "good deal", for the most part.
BUT, Best Quality....NO, certainly not...there are at least 10 manufacturers that build higher quality, and some don't charge any more for it(Active Thunder).
But, as I said they are a fast hull. And yes, Donzi & Formula are 2 of the ten.
I will start off saying I owned the 38ZX donzi and it is 9'3" wide as is the Powerquest 38, the Baja '38 and even bigger up into the 45's of the following boats. The beam truly makes a lot of difference in the ride when it gets sloppy out. I have not been in the Fountain 35 but tied up to a brand new 35 with the 525's on Lake Michigan that was a gorgeous boat, very small cockpit, very small cabin, and said he was struggling to get it much over 95 because it got to be a handful. That was directly from his mouth. I was in the 38 ZR and it rode on rails at 88ish with 4 large adults and less than half a tank of fuel with custom props. Every Formula I have been in, the 35, 38 and 419 have been nice boats, not much more room than the Fountain due to narrow beam, 8'3" I believe. As usual I think you need to value where and what type of conditions are the most important and prioritize from there. I was not thrilled with the cabin of the 38zr but it also ran about 10mph faster than the ZX due to a less than 5' cabin vs nearly 6' cabin height and less beam drag. Anyway, speed is not always everything if you can not handle the conditions at those speeds. Good luck.
