-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   late 90s 22 zx questions (https://www.offshoreonly.com/forums/donzi/202798-late-90s-22-zx-questions.html)
LAKESIDE RESTORATIONS 02-09-2009 08:12 PM
1 Attachment(s)
Here is one that I had, Id have to dig a bit for others. It moved with the boost that was sure.. :).. & thanks for the PR Bill.. :)
Pete, Good to hear the boat has a bravo. Thats a plus no matter what.. ;) Yes a cam & cylinder heads or head work can also improve things.. I sent you an email by the way.. :)
Jamie :)
Last Tango 02-19-2009 03:42 PM
Pete,
Jamie is absolutely the hot ticket to get your 22ZX running right.
Here is my 3-year ownership blog with a similar 22ZX:
http://www.donzi.net/forums/showthread.php?t=44360
LAKESIDE RESTORATIONS 02-20-2009 12:11 PM
Thanks Tango :) Jamie
Fast-Truckin 02-21-2009 08:29 PM
I have a 2002 22zx with a 350mag and alpha it goes 60-62.On a 4 blade 24-inch pitch prop.
Schlim351 05-07-2009 09:57 PM
I just picked up a 98 22zx powered with a 502 and a Bravo one drive, I am wondering what prop will work the best for top speed or all around? Any 502 feed back would be great... Right now I have a 24 pitch bravo one runs around 70 mph.
LAKESIDE RESTORATIONS 05-08-2009 07:11 AM
22 B1 for power & skiing, 24 b1 is probably your best all around prop on that hull, bit a 26b1 may work for you as well with your power. It will depend on the altitude, weight, etc.. If the 26 works it will probably be the fastest prop & then the 24 would be your power/skiing prop.. ;) Jamie
Schlim351 05-13-2009 12:03 AM
Thanks for the info... FYI Im in Wisconsin, running in the great lakes it seemed like it has excessive prop torque when changing RPM. No trim tabs currently on the boat, would they be worth the effort?
LAKESIDE RESTORATIONS 05-13-2009 07:22 AM
Trim tabs can help, as set of midsize ones should work nicely if you get a little chine walking or porposing.. :) :bigbird: J
Schmidty52 07-01-2009 04:50 PM
Originally Posted by Shanghied Again (Post 2795636)
Ok here is the trick question? 350 or 350 Mag, Alpha drive or Bravo drive? What is the pitchon the prop, I have sold many of the 22ZXs BEWARE of the 350 Mags with the Alpha drives they did not hold up, to much HP running through a drive that was only good for 300hp not 310 also the 22ZX is a heavy boat 3800lbs dry, they switched to the Bravos in the 2001 up the boat with a 350 Mag on saltwater would run 62, on fresh 58. On a 1999 $19,000 without a trailer in this market is high just sold a 1998 with a trailer and a 502/415hp for $11,000
Best of Luck
Where do you sell boats? I am interested in a 22zx and live in Jersey. Any help would be really appreciated.
TomMurphy 04-01-2017 12:56 PM
What three blade should you run on a1999 22zx step hull with 454efi
