donzi 27zx
i just got my boat back on the water ill take pics later but just wanted to give you guys an update that it ran awesome. the exhaust got finished saturday night its stainless marine and when stared it up i thought my engine had a really bad know but i found out a couple minutes later that is was the flaps on my exhaust haha any ways a 20' action craft pulled up to me when i cruising at 50 and he wanted to race so i stayed with him to about 60 and then it was gettin choppy so i trimmed up my drive and ran 75 and waved goodbye arent center center consoles fun to mess with. anyways any tampa bay boaters that wanna meet up let me know:grinser010:
Originally Posted by ceDONZI27zx
(Post 2908667)
What kind of power are you running and what speeds are you seeing? |
i have 540ci merlin fully built i believe 620hp and a bravo one with imco ext. i think 12 or 16in and the motor only has 12 hrs so im still breaking it in but at 4600rpms im running 70ish what kind of boat do you have
(Post 2908849)
I wanted to move to a step hull so I bought a 26ZX. It has a Young Performance 850 SCI in it. The best I have seen in it is 103 mph. It can get kind of crazy over 90. I have a friend that has one of the first 27ZX twin steps and his runs in the low 90's. It is dialed in. How does the ext box work out. I pondered that with my 27. |
it makes the boat excellent its a 12in stand off box with hyrdraulic steering and nice set of k planes i just got the boat a week ago its an incredible upgrade from my 19ft mako and i got this boat for a steal i got the boat motor trailer new interior and a clean title for 17,200
(Post 2909643)
I would like to know more about the boats set up...Is the box 3 inch rise or is it neutral? Is this a step bottom boat ? what gear and prop are you running. I have a 97 twin step with some HP and run into the lower 90's Need some photos...nice rig Bryan |
Nice straight ZX. Those are great runing boats. I loved mine. It ran like a boat should run.
thanks it handled awesome on monday when i took it out and jumped a couple rollers
Sweet boat man... I too just got into a 27zx but it has a 502. I wish to upgrade as 57mph top speed is just not satisfying enough to me. I blew up an outdrive this weekend by (luckily) hitting a floating log...insurance WILL cover that...but towing your Donzi with your buddies 18' larson deck boat sux. I've been eyeballing an XR drive so I can do a rebuild on the engine right. If everything works out maybe the drive part will be **free. Anyway what drive do you have on yours?
Originally Posted by onelightmind
(Post 2923556)
Thanks ZXXX thats what I was leaning toward... we will see what the insurance numbers look like and if the BIII drive has a scrap value. Props look like they could be repaired easily...
I was told the XR would bolt up easily to existing BIII stuff is this true?? |
(Post 2924343)
From what I was told it will bolt up, you just have to change out the gimble bearing since the XR has a larger input shaft.
That's what I have heard. Someone also mentioned I should upgrade my B3 upper to XR and have em beef up the lower??? confised a bit by this suggestion... still waiting on the damn adjuster.
(Post 2925253)
Enough said... If I can do it I will loose the B3
help help
new to this site.running the old 1998 twin step 27 zx donzi race boat.(damn donzi).thing flys for a F1.my problem is when I trim to get my top speed.It dont even get a small tail at all and it ununhooks and spins out.Is this a stepped hull thing or what.every one else running Bravo ones can spit pretty high.hull to shaft is 7",running a sport master,swinging a26"four blade bravo. any help would be great.
Originally Posted by Brock Donzi
(Post 2976836)
Prop technology has improved a good bit since they built your hull. You may be able to play around with your X and props to get it settled out. |
| All times are GMT -5. The time now is 09:10 AM. |
