Go Back  Offshoreonly.com > Owners Forum > Donzi
Prop help for a 38 zr >
Old 07-27-2011 | 11:42 AM
  #31
Yea XR's.
Thanks.
38zRgUy is offline
Old 07-28-2011 | 06:51 AM
  #32
SS930's Avatar
Do you know what exactly failed in the drive?
SS930 is offline
Old 07-29-2011 | 01:45 PM
  #33
The upper blew apart. I guess it looked like a tooth broke free and tore everything apart up there...
38zRgUy is offline
Old 07-29-2011 | 02:00 PM
  #34
SS930's Avatar
That's the usual, probably not related to the prop though. If the other drive has the same hours on it, you might really want to think hard about tearing it apart too and replacing the upper gear. The gear is expensive (~$1500?), but it's a lot cheaper to catch it before it goes than to have to replace the entire upper.
GL!
SS930 is offline
Old 07-29-2011 | 02:15 PM
  #35
SS930's Avatar
BTW, you might want to look into this if you're planning on keeping the boat or really running it...
http://www.offshoreonly.com/forums/g...-question.html
SS930 is offline
Old 07-29-2011 | 02:45 PM
  #36
you need to cut out the caged roller bearing that comes with the gear set and replace it with a larger roller bearing(torington). use the same snap ring to hold the bearing in. doing this will take the rock out of the upper gear set. That is coming from a guy that blew a lot of uppers because of mercs screwed up design from the factory.
302Sport is offline
Old 07-31-2011 | 06:55 AM
  #37
vette131's Avatar
friend of mine just bought a new 38zr with 525's & it came with 34 maximus wheels. we ran it yesterday full of fuel & all it would run was 82 but rpm was 5000 with the trim set on 3. way high slip numbers for 5 blades. I don't think his boat would get up with 4 blades. any thoughts?
vette131 is offline
Old 08-02-2011 | 10:49 AM
  #38
it'll bite harder with 4 blades and run the same speed but a little lower in the rpms. About 4800 to be exact. You'll be able to hang the drives out a little bit more also if you wanted to. The boat won't do more than 82-84 with a full load. You won't see the mid to upper 80's till half tanks.
38zRgUy is offline
Old 08-11-2011 | 04:28 PM
  #39
Originally Posted by 38zRgUy
I have a 38 zr with staggered 525's currently running 34 pitch 5 blade labbed props. Was out this weekend and was hitting the rev limits at about 80 mph. I know the boat has more than that. Any suggestions?
Some of the 38Zr's previous to 2009, built with 525's came with "shorti" lower drive units. With 1/3 tank gas (60-75 gals) they can go 93mph. If you run with over 1/2 tank
(over 100gals) the center of gravity changes some forcing more trim and causes overreving wasting power (watch for the rooster tail). The more gas in the tank the worse it gets. (I imagine you may have shortis and were running with about 3/4 tank)
Try running with 70 gals of gas to see if what I'm saying is BS. It won't cost you a thing. When you find it's not BS you have 2 options: 1) Run with 90 gals or less, 2) Use longer lower drives combined with new props to match (You'll dig more and can trim approprietly).
Good luck!
My Donzi is offline
