Total Length of Classic 18 from front of trailer to prop
Looking at using a Donzi Classic 18 for a project, but need to know the overall length of the entire boat on a trailer to see if it will work for my application and for storage. Looking for how much room I need from front of trailer back to the prop. Thank you!!
----Kind of hard to do without knowing more about the trailer.......Bill S
the specs I have on the older volvo 18's are 19' 4" including the outdrive so I would say the boat by itself with the drive up is 20 feet easy and as Bill said tough to guess without knowing the trailer, my 19 hornet on it's trailer is all of about 27 feet tip to tip with the drive up i have seen some use a swing away tongue trailer and removing the outdrive to make fit in the garage when space is tight
My 18' sutphen with volvo 290 and swing-away tongue trailer was 24 feet. I fit her diagonally in a short 18 foot deep 2 bay garage. Tight as could be though...
Thanks! I have 24' deep bays. I could angle it a little bit. Just looking for some rough measurements to see if I could squeeze one of these on a trailer into one of my bays. Keep em' coming!
My 18 just fits in a 22' stall without doing some unnatural things I think you should be good with a 24' space
On a steel trailer, it should fit into a 24' deep bay. Aluminum trailer tongues are usually longer.
| All times are GMT -5. The time now is 05:32 AM. |
