-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   Top Speed 38Zx (https://www.offshoreonly.com/forums/donzi/335280-top-speed-38zx.html)
prospector 03-09-2016 12:53 AM
Top Speed 38Zx
hi all! new to the forum! we are currently "prospecting" a 02 38zx with 600's in it (not sure if they are 600sci, or other motors tuned up) (will find out this week) but with 1200hp what speeds should we expect from this boat?? high 70's-low80s about right ?? its a non daytona and has some sort of 4 blade props on it with xr drives! thanks in advance !
1989mach1 03-09-2016 06:31 PM
I would think with 600's u might see high 70s. My 33 with 500's four blades seen best of 83 only once but see upper 70's all day any day.grate boats but heavy boats but one thing I can say in there size range you will not find a bigger more roomy cabin. If that is important to you as it was us you r on the right track.
Wilks 03-09-2016 08:45 PM
Should be around 80.
s022mag 03-18-2016 05:03 AM
My 38 with 500s ran 72+ with 5 blades
MullenTJ86 03-18-2016 07:34 AM
I would think a 38x (non daytona), you're mid 70's no prob with a full boat, might reach 80 on a good day.
zDonzi 04-06-2016 01:34 AM
I have a 2004 38ZX Daytona twin 525s with Whipple Chargers (~1600hp) XR ITS drive Magnum 5 blade 32 pitch prop. 3/4 tank full, it runs 86 mph at 5000 rpm. I think I can reduce the pitch to rev 5800 rpm for more mph. Heavy but solid stable ride!
lonestar382 05-10-2016 05:59 PM
86 is slow for that power. My 01' daytona with innovation 600's turned labbbed Bravo1's 34p and ran 84-86 consistently. Something isn't right with your setup if you're seeing the same with the power you're indicating.
