Go Back  Offshoreonly.com > Owners Forum > Donzi
350 Mag engine wake up >
Old 08-28-2016 | 07:53 PM
Default 350 Mag engine wake up
I now have about 60 hours on my Jasper 350 mag and want to wake it up with a cam and set of heads. Any suggestions. Also I thinking about reprogramming the ecu .
Donzi Z22 is offline
Old 08-29-2016 | 07:24 AM
Pat McPherson's Avatar
If you have an EFI engine, I'd consult whom ever is going to reprogram it. Builders that reprogram / build EFI engines will have a proven package. Changing the cam and heads then trying to reprogram the ECU after to match after is vary difficult unless done on a dyno. With a carb engine, you have many more options...
A good high flow exhaust system is always a great place to start to wake up any engine...
Patrick
Pat McPherson is offline
Old 08-29-2016 | 07:37 PM
Do you of any that I can contact ?
Old 08-29-2016 | 09:03 PM
If you're in Woodstock you might want to give Pro Boat a call. They can probably point you in the right direction.
Belli is offline
Old 08-30-2016 | 12:37 PM
post in Q&A and you'll get lots of suggestions about who to use.
Patrick
