Complete rebuild hotrod / show 22 Classic
I'm building a Donzi 22 that I'm shooting for a balance between speed/power and showy. Planning on putting 800 to 950HP BB in it. Only thing original at the end will be the fiberglass. Seriously EVERYTHING will be new. I've done dozens of hotrod cars from frame up. This will be my first boat. My last boat was an 02 Fountain Lightning with twin 575s upgraded. That boat did 100 at 5,100 feet.
Since this is my first boat build I'm looking for good advice for 800+ HP drive / prop styles. Durability, eviciency, speed. I have available 2001 Speed 6 that uses off shore style prop but i don't know if that's a good choice. Any educated / experience help or good referrals will be appreciated! Thank you. |
Welcome to the board and tons of good info here as well. Fastest recorded 22 so far is 112.6 which is damn impressive but hard to get info except we know it's a procharged big block not sure on drives. Most best setups depends on your x-dimension. Most run a -2IMCO lower if 2000' model or older. Some of the newer ones have higher x-dimension. I also have a 22 that will be running decent power 600 or so.
KRAUSMOTORSPORTS Thank you, I spoken with a couple guys who built high HP 22s. Both said they've experienced prop walk. Both said they went with a SCX upper and a 2imco lower. That seem to correct the prop walk and still have a strong durable drive.
What is your 22's top speed with 600hp, what drive and what elevation are you at? Thanks again. |
Originally Posted by imagemaker7777
(Post 4504536)
| All times are GMT -5. The time now is 12:06 PM. |
