Go Back  Offshoreonly.com > Owners Forum > Donzi
Best Prop to Run 35zr 525 side by side >
Old 06-09-2025 | 07:01 AM
Default Best Prop to Run 35zr 525 side by side
I recently bought 35 zr with twin 525 xr drives side by side. It has a Bravo I 4 blade. I feel Like I should be getting some more top-end speed. Running about 75 WOT
d4laseck is offline
Old 06-10-2025 | 05:21 AM
neva satisfied's Avatar
That boat with that set up should run 92-94
neva satisfied is offline
Old 06-10-2025 | 08:40 AM
Sydwayz's Avatar
Forum Regulator
Very often when one buys a boat it comes with the worst set of props the previous owner had, or even their buddy.
Give BBlades.com a call and get a recommendation, and see if they have some you can borrow.
Sydwayz is offline
Old 06-10-2025 | 10:21 AM
That is off, my buddy with the same boat and stock 496HO ran 84 in the shootout a couple years ago.
Wildman_grafix is offline
Old 06-10-2025 | 10:47 AM
F-2 Speedy's Avatar
At least tell us what props are on it..........
F-2 Speedy is offline
Old 06-10-2025 | 01:59 PM
Sorry, it has 31 pitch. I thought I put that in the original post.
d4laseck is offline
Old 06-10-2025 | 03:55 PM
F-2 Speedy's Avatar
I was going to say 30 or 32's........is this a step bottom ?
Old 06-11-2025 | 05:51 AM
That boat with 525's/XR's should have a set of 34p 4 blades.
Old 06-11-2025 | 08:36 AM
Full throttle rpm, prop type, size and pitch, tab and trim setting from neutral will help a lot.
