DW Flats boat
Pics from DW Jr today. After the green kote is applied, the putty is applied. These 2 coats are applied to prepare the female mold for milling, to cut using 5-axis CNC, into a smoother surface. The male plug build is bypassed to save time and to lower the cost of the build.
The 5-axis CNC machine has been busy. shown here is the milling of the DW Flats Boat
The bow area has still the rough putty, where as the areas astern has been milled. This process continues with finer CNC (drill) bits till the Wright Engineers are satisfied.
When objects are designed utilizing CNC machines, the objects, when completed, are perfectly symmetrical, as opposed to building an object using our eyes for approximating the object's symmetrical characteristic
The deck has been milled and coated. Getting ready for putty application then CNC machine again with finer and finer CNC (drill) bits
The hull will be sanded down to 2000 grit, then gel
