What's wrong with my drive? >
Old 05-12-2007 | 09:43 PM
Default What's wrong with my drive?
XR drive. Put in in last season and it ran fine. As the season went on it started taking longer and longer to engage into reverse. By the end of the season it wouldn't go into reverse at all. No grinding or noise of any kind, shift lever moved smoothly, just no reverse. When I drained the oil no metal at all. Adjusted the linkage over the winter which seemed like that might be the problem. Ran it on the trailer this weekend and forward and reverse both worked fine. Put it in the water and no reverse. This has me baffled. Anyone have a ideas as to the problem.
CN24 is offline
Old 05-12-2007 | 11:55 PM
Mr Gadgets's Avatar
Charter Member #601
If the cable linkage adjustment doesnt do it.. then you have a problem with the cone clutch. Do a search for shift cable adjustments.. I have posted how I do it to check for problems with this type of problem.. let me know if you find it..
D*ck
Mr Gadgets is offline
Old 05-13-2007 | 04:41 PM
If you take the long cable off at the engine and shift the short shift cable at the engine that will tell you if you have adjustment problem or a drive problem.
spunky is offline
Old 05-13-2007 | 07:07 PM
thanks for the help. Disconnected the cable as per spunky, towed the boat to the ramp,and lowered it into the water. Went to start it and the starter broke. Never got a chance to try it. Will change the starter tommorrow and try it again. Also found your thread Mr. G about linkage adjustment. Hopefully the drive will engage with the cable disconnected and I'll just need an adjustment.
CN24 is offline
Old 05-13-2007 | 08:58 PM
Mr Gadgets's Avatar
Charter Member #601
Good luck Carm.. let us know what u find.
Old 05-13-2007 | 09:22 PM
Tinkerer's Avatar
HI MR GADGETS - Site wouldn't let me say HI D I C K
How busy are you ???
I need to have one of my drives looked at.
The top seal is leaking grease into the bellows.
Steve 723-1720
Tinkerer is offline
Old 05-14-2007 | 04:54 AM
Mr Gadgets's Avatar
Charter Member #601
I am swamped as always.. but a seal is a quick fix.. I will give you a call and see what we can do for you.. I remember that warm feeling all winter while working in my shop.. Thanks again for that!!
D*ck
"Proud to have a name that is banned on the best boating site in the world"
Old 05-14-2007 | 11:42 AM
Hi ya D*ck I am still kickin
Darkspoilerzx is offline
Old 05-14-2007 | 05:44 PM
Mr. G,
Replaced the started and gave it a try again tonite. Shifted into reverse using just the cable but a long hesitation before engaging. I'm assuming then it's the clutch cone. Mechanically I'm sure I'm capable of replacing it. My questions are:
1-Any special tools needed?
2-Will it require resetting any gear lash or shimming or can I just replace any shims as they are?
3-Is the spanner wrench required to pull the input shaft generic or is it a mercury tool?
Once again thanks to everyone for their help.
CN24 is offline
Old 05-15-2007 | 05:57 AM
Mr Gadgets's Avatar
Charter Member #601
Carm,
the tool for the input shaft is a Merc item. The clutch kit is #52-865344A01, comes with new springs. You want to inspect the cone and the gear for wear. You should find the ridges on the cone flatened.. and hopefully the gear surface is smooth. You can polish it up with some 600 grit..
You will be able to reuse the shims if all looks well inside, just replace the clutch and reassemble.. if you have any questions.. 616-403-1006 cell
Hope that helps..
