bravo one 1.5ratio in arriva 2450
Help needed, I broke my lower unit and got a new one. I had Mirage 23" ss-prop and my boat took 6000rpm/60mph in tacho. I think that there´s been quite much slip because high rpm, what kind of experience have you with arrivas and props that hold and work well?? vessel is 24feet 21degr v-bottom and engine 454ho magnum. Thanks already, Roope from land of thousand lakes - Finland!:evilb:
I have several freinds that have had arriva's and they both ran bravo I props, costs you a little top end, but work great for hole shot and mid range.
I wonder how the size affects when my recent prop is 23". I´ve been thinking bravo1 or rev4 also by myself. They both are a bit larger diameter than old mirage. Should I also insert couple inches of pitch?? anyone??
what was your top speed at 6k rpm's?
have you verified your tach? if your tach is spot on the you would need a 28p 3 blade prop to get you in the (safe) rpm range of that motor.Not sure what you would need in a 4 blade maybe try a 26p |
HI, thanks for helping answers. My top speed at 6k is about 56-60 depending water.. I had to make already my decicion and ordered a rev4 26". I still keep my old mirage 23" in storage. I´ll be inform after testing the rev4. R
good luck the rev 4 is a nice prop, but your tach sounds like its off by 1000. I could see you doing 60 with a 23 at 5000. maybe the prop hub is slipping. please let us know how you make out. artie
Hi, got the new prop (protech 25" 4-blade) max rpm is 4600-4800 and goes about 55-60, cruisespeed at 3000rpm is 40. I´m quite pleased..
| All times are GMT -5. The time now is 02:22 PM. |
