Bravo 1 upper gears >
Bravo 1 upper gears
Bravo 1 upper gears
Old 07-10-2007 | 07:51 AM
Mr Gadgets's Avatar
Charter Member #601
Illusive,
The stock back cap has some slop in where the detent balls goes, but not to excess.. You could run it once without the detent assembly if you were careful, that would tell you if that was the problem. But, you want to be careful shiffing it.. It should shift real easy and might not find Neutral very easily. But for a test, before you bought the gears.. ??
D*ck
Mr Gadgets is offline
pettem
Drives and Lower Units
28
08-02-2022 01:46 PM
Hot Boat
12
12-22-2007 12:27 AM
johnnyboatman
05-02-2006 07:15 AM
otis311
6
06-26-2005 09:55 PM
2Slow
17
08-23-2004 12:13 PM
