Drive Spacer
Old 06-20-2007 | 12:52 PM
Default Drive Spacer
Do you guys think a drive spacer will help my slip# i have high slip# 20-21% just looking to get this number down
awsomethunder is offline
Old 06-20-2007 | 08:15 PM
monstaaa's Avatar
it may. you may also have other issues, hook rocker, bad prop , etc,,, .
monstaaa is offline
Old 06-21-2007 | 06:36 AM
excursion's Avatar
I installed a 1" spacer on mine and it really helped. I had 24% slip and it went to 14%. You need to check and see where your prop shaft is to the bottom of the boat.
excursion is offline
Old 06-21-2007 | 06:54 AM
How do i check this x-dimension and what should it be?
Old 06-21-2007 | 09:19 PM
monstaaa's Avatar
measure from the bottom of the boat to the center of the gimbal.
monstaaa is offline
boozer
Do It Yourself, Boating on a Budget
14
01-08-2019 08:47 AM
SCARAB98
Wanted
3
11-17-2008 01:09 PM
Noel35
Wanted
1
10-30-2008 12:05 PM
JohnS
Drives and Lower Units
12
07-07-2008 11:46 AM
Pure Energy
Superboat
32
06-23-2006 05:14 PM
