Engine removal with TRS drives
I am pulling the engines out of my scarab today and am wondering if you disconnect the transmissions or pull the engines and trans together. Thanks!
Eric |
i've always pulled the engine and trans together after i've removed the drives of course.- jeff
I pull the engine and trans together. You can leave the drive on if you have enough room to pull the motor forward. Then I pull the drive before putting the motor back in just so I have less parts laying around
Mark |
I left the trans's in and just split them at the bell housings. I was a little challenging to get them resplined with the engine mounts.
Just spend the money on a new ride Eric:D
| All times are GMT -5. The time now is 10:09 AM. |
