-   -   XR ITS removal ? (https://www.offshoreonly.com/forums/drives-lower-units/162937-xr-its-removal.html)
littledcsrodshop 07-09-2007 09:02 AM
XR ITS removal ?
Would anybody be kind enuff to give me a typed out removal guide on a Bravo XR ITS. I am pulling both drives , transom assemblies , engines , ect.. also all steering including the helm. I know I will be removing in the order of drives , then engines , & then transom assemblies. But since this is a first for me on a bravo drive & the ITS transom I am not ashamed to ask for a good detailed map so I don't do anything stupid , or cause myself any extra work.
Also were would be the best place to break the hydralic lines ? Like I said I will be removing everything as far as steering goes incl. the helm.
I wish I had a good mec. manual for the ITS's but I don't , However I have faith in my OSO brothers to come through for me. I am sure it would help someone else here on the board in the future too. Thanks guys , Scott
littledcsrodshop 07-09-2007 08:39 PM
Anybody ???
Falcon 07-09-2007 09:08 PM
Very similar to doing standard Bravo's. Disconnect, cap/plug engine power steering connections, disconnect electrical connections, throttle and shift cables, disconnect cap/plug fuel connections, remove exhaust hardware, pull engines. Disconnect, cap/plug the hydraulic connections at the ITS connection block mounted on the inner plate. Remove inner transom plate, remove ITS outer transom assembly.
Lot easier to talk about!
