installing #4,s
Old 07-29-2007 | 11:05 AM
Joey put Brodix 2 X heads on these motors .t hats where the high torque numbers came from .Loweredthe boost from 9 # to 7# Dyno pull with 9 # was over 1100. Hadto detune to save the drives and it broke anyway .So we try try again !
boatman747 is offline
Old 08-03-2007 | 06:23 AM
The big shaft is/was available in IIIs' and IVs' also. There is little difference in the torpedo for the propshaft itself. Though the internal configuration varies, they use the same front and roller bearings. The V does not use rear taper bearing. However the housing does protrude slightly where the larger pinion bearings are in the V drive lower. Vs' are virtually identical in hydrodynamics to IV drives.
rhinoLX is offline
Old 08-07-2007 | 11:15 PM
Originally Posted by boatman747
Im going from 1.3 to 1.4 I want more RPMs
I am installing almost the same set up also, I have 1.5 ratio big shaft #4's but need something around 1.3. Would consider a trade
Matt
waverunner33 is offline
Old 08-08-2007 | 01:11 AM
BigSilverCat's Avatar
I have two #4's one has 1.125 gear ratio and the other is 1.68 I have the whole thing, standoff boxes gimbles drives wingplates steering , if any one can use that stuff.
BigSilverCat is offline
Old 08-08-2007 | 05:01 PM
kaama82's Avatar
Bigyellowcat, PM me your number, I could possibly be interested.....
kaama82 is offline
Old 08-10-2007 | 12:09 PM
I have a fresh rebuilt pair of 1:5 ratio small shaft #4s and gimbals if anyone is interested. Just have not got around to listing them in the classified yet.
Bigyellowcat,
would you be interested in parting out any of your stuff? I need a set of wing plates.
Jim
Lunatic Fringe is offline
ripley
4
06-26-2005 07:52 AM
CN24
8
05-17-2005 09:15 PM
Quiet Storm
Detailing, Painting, & Fiberglass
3
04-29-2005 08:22 AM
38KV
Scarab
22
10-27-2004 11:49 AM
Chris288
0
10-11-2002 12:56 PM
