Originally Posted by articfriends
(Post 2236882)
Max Machine worx uses std bravo cases and installs their steel towers,its STRONGER then a stock xr tower,the case is identical other wise,too bad your buddy didn't take his a step further,Smitty
I'll ask.....I thought he had a tower put in them but not sure. (and it could have been someone elses towers???) |
Unless you have steel towlers don't even think about it.
Thanks for the input guys. Do the satndard bravo xr's have the steel tower built into the case or is that a bennefit of an aftermarket upgraded drive?
1 Attachment(s)
Originally Posted by cstobe
(Post 2237947)
cstobe,
All the Merc XR drives have a steel tower in the case as standard equipment. I have not seen one fail as of yet. I have seen a gear welded to the tower but the tower did not fail, just got very hot when the gear bearing failed.. My steel towers have 2" of thread on them, better than the XR Merc tower, but not as good as Max Works. Although I have not had any failures with my towers, and I dont charge an arm and/or a leg to do it. Smitty, isnt there a change to the bottom of the case that was a problem when you tried to put a spacer in between the upper and lower with the Max works tower? D*ck |
| All times are GMT -5. The time now is 03:39 AM. |
