Bravo trim pump
Old 08-20-2007 | 02:22 PM
carter38's Avatar
Default Bravo trim pump
I was just curious does a bravo trim pump have the same force pressure up and down or are they different. I think I crossed one of my lines and changed the wires to get by but was wondering if it needed to be changed now if I am okay to run till I get time to switch the lines.
carter38 is offline
Old 08-20-2007 | 04:33 PM
They are different, up is higher pressure.
Nova 26 is offline
Old 08-21-2007 | 09:57 AM
carter38's Avatar
Thats what I was thinking do to after I tried this.
carter38 is offline
Old 08-22-2007 | 05:38 AM
Switch the lines. I did the same thing. The drive would not trim out when on plane.
bl
badluck is offline
Old 08-22-2007 | 10:43 AM
carter38's Avatar
I switched everything over last night hope everything is good now. Thats what was going on I went to trim and under a load it wouldn't. I figured then the pressures had to be different.
carter38 is offline
CNC
2
06-10-2006 07:36 AM
427 larry
9
08-22-2005 10:10 AM
SeaWeasel
2
07-21-2005 04:29 PM
tomas_wallin
4
04-18-2005 02:59 PM
Rambunctious
04-22-2003 06:37 AM
