# 6 drives........ >
# 6 drives........
# 6 drives........
Old 08-21-2007 | 09:18 AM
INDY27's Avatar
Default # 6 drives........
What is the difference between a dry sump vs wet sump? Any pros or cons with wet sump or maintenence issues?
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 08-21-2007 | 10:05 AM
jryan26's Avatar
I think the wet sump just robs more HP.
jryan26 is offline
Old 08-21-2007 | 10:34 AM
tblrklakemo's Avatar
SeaRay Sundancer
Dry sump has remote reservior and return with oil sprayers? The gears dont run in a bath of oil, just get sprayed with fresh cooler oil from the external sump?
tblrklakemo is offline
Old 08-21-2007 | 11:02 AM
Dry sumps have the oil reservoir in the lower unit. Dry holds about 4-5 quarts of Torco oil and the wet holds about 4-5 gallons of Merc HiPerf sterndrive (or similar) oil. Most of the wets had a reservoir inside the transom.
Dry sumps are more efficient.
Try searching dry sump in the forums: there's a lot of info already posted.
Due
Dueclaws is offline
Old 08-21-2007 | 11:19 AM
Default dry #6
prop rotation matters on a drysump as the prop shaft turns the oil pump,wrong rotation and you suck Air instead of pumping oil... a drive set up to run LH in foward must be run LH rotation.....or so I was told. I'm newer to these #6's but man are they built nice in side
those oil pump housings are pricy.
soinc is offline
Old 08-21-2007 | 12:00 PM
All #6s (wet or dry) are rotation sensitive.
Due
Dueclaws is offline
Old 08-24-2007 | 07:49 PM
INDY27's Avatar
Thanks for the feedback......any issues with the wet sump #6 or are they pretty much bulletproof?
INDY27 is offline
Old 08-28-2007 | 12:07 PM
HUSTLEthis's Avatar
bulletproof...just like the dry-sump...same gears, minus the oil pump
HUSTLEthis is offline
Old 08-29-2007 | 05:30 AM
If you are thinking about replacing you brovo's with 6's here are a couple of things to think about
The 6's will add about 700 lbs to the total weight of the boat and of course all the weight is in the back and may upset the balance, you will need to move the engines forward to make room for the trans or crash box, Props are 2X or 3X more expensive than brovo props. Power steering pumps and metering valves should be considered, spacers for 6's are more expensive that brovos when you are dialing this in, tie bar will have to be replaced, if the engine is moved forward tail pipes will have to be longer, sea strainers moved etc...
James is offline
Old 08-29-2007 | 08:11 AM
thunderusone's Avatar
And new motor mounts....the rear has to be supported now. Bellhousings with coolers.....all new plumbing. It is a complete re-rig. but the result should be worth it if done correctly.
thunderusone is offline
