-   -   Need power steering lines on the rams (https://www.offshoreonly.com/forums/drives-lower-units/166813-need-power-steering-lines-rams.html)
Strip Poker 388 08-21-2007 11:10 PM
2 Attachment(s)
I have had 2 failures on my mayfair steering line on the steering rams.The rubber is failing inside the fitting ,the hose it fraying on the end and coming apart. I have the tool from Marine Machine to put themtogether etc, The rubber line are I guess getting old?
I want to get some made ofStainless braided line made up with the stainless fittings.
Were can I get these at a reasonable price ,any sugestions??
Rob
Strip Poker 388 08-21-2007 11:12 PM
3 Attachment(s)
blown rubber part.
I guess there chrome plated brass?
kennyo 08-22-2007 09:02 AM
Check your local Hydraulic hose shops. They can hook you up or tell you where to go. We have a couple of places here that do it. Are those ends the kind you can disassemble with wrenches? If they are you should have no problem.
Strip Poker 388 08-22-2007 12:05 PM
I was thinking if I got some they were crimp style they may hold up better?My local shop doesent have shet,there division on the coast doesent have it either.Remember im in Mississippi:D
Scarab3DMC 08-22-2007 03:28 PM
Rob call 515--407-0215 thats the guy from XS MARINE..All his lines for the pistons are HD Stainless braided !
Strip Poker 388 08-23-2007 05:00 PM
Been calling all day, busy or call want go tru.
I tried CP Perf they have them already made up ,shopping around now.
La hustler 08-23-2007 06:06 PM
http://www.imcomarine.com/nvcatalog/imco2007.pdf they make all kinds of lines dont know if it will fit your steering but go check it out .
nocigarette 08-23-2007 06:54 PM
How many psi is hydralic steering.....Cant ya just aeroquip them
[email protected] 08-23-2007 08:37 PM
those look like reusable ends strip was the previous failure on the same fitting? Imco can hook ya up good luck. SC
Lofty 08-23-2007 10:02 PM
Rob,
We can make up some custom SS lines for you, not too much $$$.
Call me and I'll hook you up in the morning.
