-   -   pinion bearing retainer nut (https://www.offshoreonly.com/forums/drives-lower-units/168087-pinion-bearing-retainer-nut.html)
Ken N 09-06-2007 03:48 PM
Does anyone make a better pinion bearing retainer nut thenthe stock nut from Merc. I have a 1999 Brovo 1 drive.
Mr Gadgets 09-07-2007 02:23 PM
Ken,
Imco makes a steel retainer nut that I have used for years. There are two different ones offered.. You dont want the the rigid one.. Just the regualar Bravo one.. I dont have the pn handy or I would tell you what it is..
After the weekend I will be able to get to it..
D*ck
Ken N 09-07-2007 03:55 PM
MR. Gadgets
I looked up Imco Marine on line and found a steel nut, part #BRV129. Is this the one to use or not to use.
Mr Gadgets 09-11-2007 08:52 PM
Ken,
that is the correct part number.. BRV129. Sorry it took so long, I was out boating.. for a change!!
D*ck
