-   -   Drive fluid for Volvo?? (https://www.offshoreonly.com/forums/drives-lower-units/169033-drive-fluid-volvo.html)
kaama82 09-18-2007 04:46 PM
What type of fluid is used?? Any special tools needed for this procedure??
SFOcean 09-18-2007 06:33 PM
270, 280, 290 drives use engine oil for lube. Need metric allen wrench, straight and phillips screwdrivers. The allen fill plug is under the upper cover.
kaama82 09-18-2007 08:09 PM
Its a duo prop, What model is that????
SFOcean 09-19-2007 12:20 PM
the older style (released in 1982/3) is similar to the 280 drive. I do not know about the newer style or when the change was made.
txriverrat2001 09-20-2007 08:35 AM
Volvo uses a synthetic oil in the later DuoProp setups. Get the good stuff straight from the dealer - no engine oil.
senzaspectre 09-21-2007 07:07 AM
Thats what I do.
kaama82 09-21-2007 07:25 PM
Thanks for the info....
J-Bonz 09-21-2007 08:12 PM
I believe it was a mobile I synthetic
Wooderson 09-21-2007 09:34 PM
There's a general break-down of what to use in each drive here.
Racerngr1 09-27-2007 12:49 AM
I have a DPS drive and run the Merc Synthethic in it. It (Volvo) recommends that you use a 75w90 GL5 oil. I want to run the royal purple stuff but I heard that it makes the cone clutch too slippery.
James
JJS2007 09-30-2007 08:31 PM
I am pretty surer that you want to use high vis. Those drives are fun to work on
