Stripped drain screw, now what? >
Old 11-04-2007 | 04:07 PM
Default Stripped drain screw, now what?
EDIT: Wasn't sure my original post was clear, but it's the slotted head that I messed up, not the threads.
Figures it would be the 4th screw (2 vent, 2 drain) that I go to loosen that doesn't want to play along. I should've known since it looked unpainted, that it's been replaced and has already been a problem for somebody else.
Anywho, all tips and suggestions on how to proceed are welcomed.
handfulz28 is offline
Old 11-04-2007 | 05:45 PM
I'm not sure what screw your dealing with. I have had exellent luck removing stripped screws by doing the following. Of course it depends on space and how much meat you have on the screw head. Take a dremel tool and grind a deaper slot to accomidate a larger screw driver, fat stubby or something and posibliy a pair of vice grips on the shaft and bang it pops loose.
tomcei is offline
tblrklakemo's Avatar
SeaRay Sundancer
dremel moto tool.....work wonders for repairing stripped screws etc.
tblrklakemo is offline
Old 11-04-2007 | 08:01 PM
Audiofn's Avatar
Charter Member #232
Ya and heat it up a bit to loosen it some.
Put your best foot forward!
Audiofn is offline
Old 11-04-2007 | 08:27 PM
Impact screwdriver?
JJS2007 is offline
Old 11-04-2007 | 08:30 PM
If all else fails I have had good luck with LH drill bits better luck than easy outs.
turbo2256b is offline
Old 11-05-2007 | 05:54 AM
If you have access to the screw head and can get a really sharp center punch at an angle you can also turn a stripped screw with couple sharp blows with hammer.
happy hours is offline
Old 11-05-2007 | 07:47 AM
Ted G's Avatar
If the screw is still basically there, you should try and cut a new slot with a dremel or a whizzer wheel (wear it smaller on something else first so it won't damage the housing). Then use an impact screwdriver to remove it. Be careful if you use a torch, you can damage the metallurgy of an older case fairly easily by overheating.
www.cbpba.com
Ted G is offline
Old 11-05-2007 | 08:59 AM
This is what I'm dealing with. Doesn't look all that bad, I just didn't have the right screwdriver head. I tried a few wacks with the impact driver, no luck. I'm VERY hesitant to give aluminum any heat...maybe I'll try a plumber's torch instead of oxy/acetylene
I'll obviously need to buy a new drain plug so I'll probably get the new one and hit the hardware store to get the right screwdriver/tip whatever. Then I'll see if I can make the groove deeper on the stuck one.
Thanks!
Old 11-05-2007 | 09:28 AM
Audiofn's Avatar
Charter Member #232
That aint stripped, go get the correct screwdriver with a nice new tip and put a little bit of heat on it (being carefull of the seals) and out it will come easy as pie. Snap On makes a great short screwdriver with a big head that works perfect for that. I am sure that Craftsman has a copy of it.
Jon
Audiofn is offline
