What is a bravo x drive ? >
Old 11-10-2007 | 05:11 PM
Default What is a bravo x drive ?
I have a bravo x on my 04 nordic heat. What is the deal compared to a xr bravo 1 or xz. I have a 500 efi and I am installing a supercharger. I just bought a imco lower but need to know about the upper. Thanks John Lomant
johnlomant is offline
Old 11-10-2007 | 10:02 PM
fountain4play's Avatar
Here's a link that does a good job of detailing the differences and might be of some help...
http://www.mercurymarine.com/engines...ecs.php?ID=120
fountain4play is offline
Old 11-12-2007 | 04:00 PM
Mr Gadgets's Avatar
Charter Member #601
John,
If the new setup makes gobs of midrange torque, and you drive it wrong.. you will end up knocking the teeth off the pinion gear. But if you drive it with respect.. you may just make it work.
The X has the thick floor helical cut gears, and a steel tower in the case. Those are good things! If you make/use enough torque to break teeth, then you will have to go to XR gears in that upper. Even those can be broken, but the chances are less with the stronger XR gears and proper setup.
Hope this helps.. if you have any questions... fire away..
D*ck
Mr Gadgets is offline
Old 11-12-2007 | 05:05 PM
Basically, the Bravo X is an XZ upper with a standard bravo lower.
Griff is offline
Old 11-18-2007 | 08:59 AM
Bravo X drive has spiral gears in upper. XR has straight cut gears in upper. Only difference.
JohnTheDriveMan is offline
Old 11-20-2007 | 08:28 PM
Mbam's Avatar
Offshoreonly Advertiser
See if this helps:
http://go-fast.com/mercruiser_bravo_sterndrives.htm
Mbam is offline
Old 11-21-2007 | 07:05 AM
Mr Gadgets's Avatar
Charter Member #601
Marc,
That was the chart I was looking for.. Thanks!!
Old 12-13-2007 | 08:59 PM
fountainfevr's Avatar
Help me out. I have a 2000 Fountain with a 502 mpi. I dont run my boat hard but I still ended up breaking a tooth off my pinion gear have to have a new upper gear set. cost me 1500. have arizona speed and marine ECM, roller rockers and lighting headers also have MSD ignition. Should I change the drive or stay with Bravo one?
fountainfevr is offline
Old 12-13-2007 | 10:51 PM
Mr Gadgets's Avatar
Charter Member #601
How big is the Fountain?? Single or twin?
Old 12-14-2007 | 11:27 AM
27 fever single engine
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
1BIGJIM
Wanted
10
05-16-2008 10:12 AM
rhory
1
05-19-2004 06:52 AM
Chris288
1
04-13-2004 11:19 AM
panteraracin
3
02-07-2002 10:36 PM
