TRS Tips & Tricks
Old 11-17-2007 | 06:38 PM
Registered User
I've been hearing about Royal Purple from a pal who races BMW's. He swears by it. I'm going to try it.
Ed, you wouldn't believe the Cig. I know I said I was just going to tidy it up and run it. That didn't last. Within 24 hours of being back, the engine compartment was gutted and the transom stripped. The cockpit is stripped and off to upholstery. I'm going to strip the cabin tomorrow. I've already ordered a couple sets of JE's and a pair of BDS 8-71's for it.
Chris Sunkin is offline
Old 11-17-2007 | 06:41 PM
Originally Posted by Edward R. Cozzi
Chris:
Tres Martin used to change all his customer's TRS oil to full synthetic Royal Purple. Made them more reliable.
It seems like any more prop than the Mirage series, (3-Blade), puts a strain on the drive that eventually finishes it off.
They seem to like the 3 blades better becasue they are so low in the water.
I used some 4 blade hydro's and it actually slowed the boat down running the same rpm's
go figure?????
jeff1000man is offline
Old 11-17-2007 | 11:16 PM
go figure?????
I have had the same luck with my 20' Cigarette setup. Running a 4 blade hydro was slower and handled strange, bow steer. With the drive deep it is tough to getting a good combination. I have tried 5 different props and the best is a solid hub Mirage 25". I have a Mirage + 27" but it needs to be labbed or something. My boat has a Mertrans and I had Huber install additional clutches and beefed it up, because I wanted it to be bullet proof. TRS is a great package but I will eventually replace the drive with a Konrad. I could probably pick up 2 - 4 mph with a shorter drive.
goin70 is offline
Old 11-17-2007 | 11:51 PM
Lofty's Avatar
We've had great luck over the years with Redline Shockproof Heavy.
Lofty is offline
Old 11-18-2007 | 06:38 AM
when craig colabella buit mine , he only use's merc gear oil.. as for the treating of the gears , when i orderd parts from bam i spoke with mark and he told me that treating the gears was crap and he no longer offered that option...
as for blades , i have been told trs's really don't like 4 blades . but , i'm sure if you talk with throttle up they have a wealth of info on who's boat with trs's does what and with what prop..
open87 is offline
Old 11-18-2007 | 07:50 AM
Registered User
The 4-blades thing is simply touque loading. Like putting slicks on a car. A bit of slip softens the load.
Old 11-18-2007 | 11:29 PM
[QUOTE=Chris Sunkin;2339179]I've been hearing about Royal Purple from a pal who races BMW's. He swears by it. I'm going to try it.
Lots of guys in the Ferrari community swear by the Royal Purple in the transaxles. Works VERY well. Shifts easier and quicker, and really helps them live.
Darrell.
DMOORE is offline
Old 11-19-2007 | 12:33 AM
stecz20's Avatar
hey thats my old cafe.. i wanted to to get konrads bad, glad he did it... looks great... stecz
stecz20 is offline
Old 11-20-2007 | 07:22 AM
White Knuckles's Avatar
How do you guys think that the TRS drives would run with cleavers? Didn't they originally use them? I have 3-blade Mirage 25s on mine, and I am looking for more stern lift without going to 4 blades.
White Knuckles is offline
Old 11-20-2007 | 07:38 AM
Which Royle Purple product? (Max-gear)?
smdude is offline
