Treated Gears Results. >
Old 12-17-2007 | 01:14 AM
  #41
articfriends's Avatar
Dick,the shims are common gm 10/12 bolt rear end pinion shims, the same bearing that fits the outdrive on the big lower gear is the identical bearing/race the gm 10/12 bolt rear end uses also,ratech,DTS,randies etc sell the pinion bearings/shims real reasonable,Smitty
articfriends is offline
Old 12-17-2007 | 01:18 AM
  #42
Originally Posted by nordic95
Do you locktite all the press in races into your cases?How hard to get the races out later when you have to rebuild?Also do you find the blue tool easier then a bearing seperator plate and a press?Where can I get "THE BLUE TOOL" from?Which auto pinion shims did you find fit the best,12 bolt chevy etc.?
Thanks Anthony
I use loctite press fit assist on anything that has dissimilar metals and is pressed together (steel into aluminum,metal clad seals into aluminum,etc) to help ensure it doesn't get loose when warmed up/cooled down. The stuff is still removable though without heat so its not a big deal to dissassemble,Smitty
Old 12-17-2007 | 08:10 AM
  #43
Panther's Avatar
Frank's Marine Service
Thanks for the great info, never tried that!
Panther is offline
Old 12-17-2007 | 06:22 PM
  #44
Registered User
I have the same bearing puller from Randy's. It is way better than a press, but it is a little pricey if you rarely use it.
Here is a link.
http://www.ringpinion.com/ProductDet...px?ProdID=5277
320es is offline
hoozeyurdaddy
Wanted
2
05-29-2008 08:04 PM
THRILLSEEKER
Detailing, Painting, & Fiberglass
0
05-30-2007 07:01 AM
drypipetiger
09-25-2006 12:20 PM
SSComp
1
10-01-2004 05:32 PM
O.C.Barry
02-02-2004 11:31 AM
