Blackhawk drives. Rooster Tail? >
Old 12-10-2007 | 11:46 AM
Default Blackhawk drives. Rooster Tail?
On a 29 Scarab with Blackhawks drives does it throw any kind of a rooster tail?
nova26 is offline
Old 12-10-2007 | 01:11 PM
yes, all blackhawks will throw a rooster.
VetteLT193 is offline
Old 12-11-2007 | 11:00 AM
hunster's Avatar
They are a surface drive and should throw a nice roost. Seen them on the p29's but never saw one running more than idle. Btw it did idle fast , must be a bear to get in the slip.
hunster is offline
Old 12-11-2007 | 12:15 PM
tblrklakemo's Avatar
SeaRay Sundancer
look for airpacker....he has one a small elimiator i think? there is a sonic 31 with them too
tblrklakemo is offline
Old 12-11-2007 | 01:25 PM
Airpacker's Avatar
ya, they toss a little water in the air Fun to dock and a little brutal shifting too.
Attached Thumbnails Blackhawk drives. Rooster Tail?-dsc00020.jpg   Blackhawk drives. Rooster Tail?-dsc00016.jpg
Airpacker is offline
Old 12-11-2007 | 11:35 PM
Thumbs up
Sweet!! They ever give you any trouble Airpacker?
nova26 is offline
Old 12-12-2007 | 07:13 AM
Airpacker's Avatar
When I first rigged it, I never gave much thought to the fact that factory, they had the exhaust routed thru the drive to airate the props. I blew a vertical shaft in two trying to get on plane. Repaired the drive, designed and fabbed an airation system for the props and have since pounded 160hrs onto the drive without a failure
Building a bigger motor this winter. Will have the drive freshened and we'll see what it can take next summer.
PS, My daytona with a 500efi averaged 30 hrs per Bravo before the switch to the bh drive.
Old 12-12-2007 | 07:15 AM
Airpacker's Avatar
Oh, I also added a neutral safety switch override so I can start it in gear. Saves the big bang when shifting.
Old 12-12-2007 | 04:13 PM
Whats it cost to freshen a black hawk? What kind of speed change did you see from the bravo to the black hawk on your ride Airpacker?
nova26 is offline
Old 12-13-2007 | 08:37 AM
Airpacker's Avatar
Cost is comparable to a bravo for freshening.
Boat went from 83.2 best gps to 91.1 best gps with a stock 500efi.
