-   -   Drive oil pump (https://www.offshoreonly.com/forums/drives-lower-units/176849-drive-oil-pump.html)
DrewDown 01-06-2008 08:45 PM
Drive oil pump
I'm looking for a better way to pump fresh oil back into my bravo XR's. Opposed to the hand pump that screws on top of the quarts of oil. Any suggestions?
t500hps 01-06-2008 09:12 PM
Cheap $10 garden sprayer rigged with the drive attachment from that crappy hand pump you already have....just pump it up and sit back with a drink while it fills the drive.
Mr Gadgets 01-06-2008 10:14 PM
2 Attachment(s)
This is what I have to offer. I use it with the pump because I know how many pumps it takes to fill the drive. I used to fill with a garden pump, but a lot of times (probably headed for another cold one) it would run out and I didnt catch it. Tried timing it and that depends on the amount of psi in the canister. You have to fill the canister and becareful not to get any dirt in it.. Not that big of deal, but having a 5gal pale eliminates that. Either way, the fitting is the key to it. With the quick disconnect you can uncouple and let the pressure equalize and have a nice little handle to unscrew and get that plug in without being tied to a hose. The SS nut is a dust cap so you can plug the fitting back into the hose and not loose it or the oring and it keeps the crud out.
I have sold these to marinas and they like having two fittings so they can start filling the second drive while the first one equalizes. PM me if you are intersted in either the whole set up or just fittings..
Hope this helps.
Dick
Panther 01-07-2008 04:24 PM
I have the same pump, works great!
Biggus 01-07-2008 04:43 PM
Me too, the 5 gal pail is the way to go.
I really like your quick connect coupler. I need to get one!
Boat Doctor 01-07-2008 09:17 PM
Garden sprayer made by Chapin light blue in color can see the oil level in it at all times metal tire valve installed in top so there is no pumping comes with its own pressure release valve set at 45 psi works great not a lot of $$$
Mr Gadgets 01-07-2008 10:17 PM
do you have a link to that garden sprayer?
DrewDown 01-07-2008 10:41 PM
Thanks for all of the replies. Do any of you have a favorite place to buy the merc or quicksilver gear lube in bulk?
