Heavy duty alpha 1 gears >
Old 02-12-2008 | 03:03 PM
I would like some info on this as well.
I've got an Alpha question as well for you guys. I had great luck with them on my Scorpion with 320hp smallblocks. Any thoughts on which one is the strongest of the Alpha series? I have run Gen ones and even MR's. Even though it is an older piece the MR is a pretty durable unit as well.
If Imco made shortys for the Alpha I would have one. I've never heard one mentioned till now. As far as strength of the Alphas, the late production Alpha 1 and Gen 2's are stronger than earlier Alpha 1s and MRs. . The earlier 1 and R drives different cut lower gears and smaller vert shafts making them much weaker. Alpha 1 and early Gen 2's came with 17-28 tooth count lower gears while newer Gen 2s come with 13-21 teeth count gears. I believe the 13-21 gears are stronger than the early 17-28 gears. The 13-21 teeth are much larger than the 17-28 gears providing more surface area for gear to gear engagement. As to the upper, aside from the HD gears they are all of the same strength. The vertical DS in the MR and Alpha 1 production had a small oring groove cut into the shaft under the splines. This is a common breakage point when overpowered. Late model Alpha 1 and all Gen 2's got a vertical DS without this groove and is a stronger DS.
When I rebuilt my Alpha 1's I tried to make them as strong as possible for the new 385ci so I used HD upper gears, late model non oring DS, and 13-21 lower gears shimmed to a tight .025" with a tight backlash for additional tooth engagement.
Hope this helps.
Ryan00TJ is offline
Old 02-13-2008 | 09:50 AM
I'm not a premium member, but would be happy to post a picture for you all to see as soon as I get back to the lake to take one of my shorties! They have treated me great, and I'm pushing some serious hp through them - for an alpha anyway. I'll be up there in a week or so, and will get some pictures.
Joe Z
zdek is offline
Old 02-13-2008 | 10:22 AM
Here is a link to some pictures...
zdek is offline
Old 02-15-2008 | 04:46 PM
Joe Z
Those indeed look shorter than a Gen 1 Alpha lower. Did you get them directly from Imco? I went to Imco's site and they are no longer listed?
Ryan00TJ is offline
Old 02-16-2008 | 10:15 AM
Same here......could someone post the pic from S wake.....Im not a member there so cant see it.......are they SS's??
pullmytrigger is offline
Old 02-16-2008 | 10:40 AM
Wally's Avatar
Were doomed!
pic from SW
-Wally
Wally is offline
Old 02-16-2008 | 10:42 AM
Wally's Avatar
Were doomed!
The alphaSS is 2" sorter then a normal alpha1 they were made from 1986-1989
Heres a few other pics i found on the net....not sure if they are actuall SS dirves cause most of the ones ive seen have the silver bottom like the one above....
Attached Thumbnails Heavy duty alpha 1 gears-alphass.jpg   Heavy duty alpha 1 gears-alphass2.jpg
-Wally
Wally is offline
Old 02-16-2008 | 02:33 PM
hunster's Avatar
hmmm land and sea stern jack?
hunster is offline
Old 02-16-2008 | 06:10 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default land and sea
Problem is they are not made anymore.John
Fenderjack is offline
prostock85
Wanted
0
09-19-2008 04:26 PM
Pantera24
8
09-11-2006 10:20 PM
Jnewton
Prop Talk
4
05-11-2005 02:58 PM
Dock Holiday
06-03-2002 09:57 PM
