-   -   nose cone good or bad (https://www.offshoreonly.com/forums/drives-lower-units/181200-nose-cone-good-bad.html)
bajabob 03-02-2008 01:32 PM
will it make your boat faster:readinghelp::argue::boat::ernaehrung004:
jhiguy377 03-02-2008 03:22 PM
my understanding is that it wouldn't really come into play until 70+ mph
Audiofn 03-03-2008 05:59 AM
It depends on what drive and how fast your boat it. If your boat is slower and you put them on then most likely it will go slower. If you are going fast enough that you are getting prop blow out at speed then they may help you go faster.
Jon
Mr Gadgets 03-03-2008 07:13 AM
If you are running the short bullet lower unit, (they were around in '88') then the nose cone is needed at a slower speed. I hit a wall at 75mph with a short bullet, the nose cone helped break thru that wall. The present day lower is longer and good to 80mph or so. Although if you need excessive trim to free up the boat a Hydromotive cone will help that.
Best thing to do is find someone with similar setup and see what they have had sucess with..
Hope that helps.
Dick
scarabfun 03-03-2008 07:40 PM
call bob at bob's nosecones he will know. i was ready to buy some for my trs drives but he said don't bother unless your doing over 80 +. i run about 76 so i didn't
scarab31 03-06-2008 09:41 AM
contact info help!
Do you have contact information at Bob's Nosecones? I have one nosecone missing off my 89 Scarab 31 Excell with Bravo drives and stock engines, (for now). Do I replace the missing nosecone or get rid of the one still in place???
scarabfun 03-07-2008 12:27 PM
i'm not sure i'll ask my dad if he still has contact info for him. that was a couple years back. take it off and see if there is any diff.
31scarab31 03-07-2008 06:22 PM
http://www.bobsmachine.com/cones.html
whatabout1 03-07-2008 06:35 PM
Also you are adding more side length to the drive.
So steering torque may increase.
Hydrolic steering is recommended.
bajabob 03-08-2008 05:54 PM
ya i order the steering hope to get iy friday
