Xr Swap Help
Old 06-03-2008 | 08:29 PM
Default Xr Swap Help
Ok, so like everyone told me, my standard bravo on the back of a heavy single engine failed for the second time in about a year. I'm in the process of looking for a XR. My question is, if I get the mercruiser PN# 30-862540A2, wich is the gimble bearing conversion kit, can I use my current transom assembly and gimble housing? I was told this was all I needed , is this true? This is the first time I make this swap so I'm kinda in the dark. Thanks.
Scott
fast22 is offline
Old 06-03-2008 | 09:02 PM
Scott
What year is the Housing, and is it a HP housing? Just curious but really all you need to do is change the gimble bearing and you are good to go.....you may already have an upgraded bearing in there ...look after wiping the grease away and check for a red dot @ 10:00 if so you have the propper bearing
Bryan
Bryan Rose is offline
Old 06-03-2008 | 09:06 PM
t500hps's Avatar
21 and 42 footers
Not sure if that is the proper part number but a bearing swap is all that is needed to except the XR input shaft.
t500hps is offline
Old 06-03-2008 | 09:11 PM
Thanks for the help guys much appreciated. By any chance would you know if my twinramsteering cap will fit the back of a swept back new bravo style if it came off of the old style? Just a shot inthe dark. Thanks agiain for the help as always.
Scott
fast22 is offline
Old 06-04-2008 | 03:27 AM
tomas_wallin's Avatar
Scott
I've been told the old caps will fit the swept uppers...
tomas_wallin is offline
Old 06-04-2008 | 05:40 AM
Mbam's Avatar
Offshoreonly Advertiser
Yes, that is the correct kit. Has everything you need. You can see a photo here:
http://www.mercruiserparts.com/partsByNumber.asp
Rear cover will fit, just will not match the profile cosmetically.
PS - we have both old & new style on the shelf
Mbam is offline
Old 06-04-2008 | 09:47 AM
I just installed one last night.
Don't forget the spacers in the trim cylinders.
I also read a Mercruiser service bulletin from September 2000. It has a page about replacing the U-joint Bellows Sleeve with a new Bellows Sleeve part no. 862209.
There was a previous post to this question saying this should only be a problem on late 90's early 2000 models.
My RED dot was more like the 11:30 position. When I installed I just made sure the grease hole lined up. I always put a black line on the bearing to make sure its lined up. I don't know how it ended up at 11:30.
I started mine last night, ran it for 10 minutes, turned the wheel all the way to the right and left, trimed up and down.
Then I took the outdrive off to check for any clearance issues. (no metal shavings or shinny spots)
Looked fine so I am going to splash it Friday.
1BIGJIM is offline
Old 06-04-2008 | 01:05 PM
1bigjim, Thanks for the help and good luck with the splashdown!!
Scott
fast22 is offline
JasonSmith
Baja
4
11-25-2005 01:32 PM
open87
07-13-2004 08:11 PM
Cigaretteman
3
04-12-2004 08:53 AM
traviss
9
11-21-2003 06:16 PM
mikev
10
12-13-2002 09:10 PM
