-   -   Heat Lamp (https://www.offshoreonly.com/forums/drives-lower-units/192013-heat-lamp.html)
nordic95 07-27-2008 08:07 PM
Heat Lamp
Just wondering if anyone uses the Merc. heat lamp when removing bearing races when rebuilding an out drive?Does it really make it much easier and how about using a heat gun.I was thinking the steel race would expand faster then the aluminum and make it harder to remove?Any thoughts
Thanks Nordic95
Vinny P 07-27-2008 09:22 PM
I have used M.A.P. gas to warm up drive cases with success. Most times, you dont need to. However, you need all the help you can get, when getting a broken lower vertical shaft bearing out of a case.
