Boxes and lowers?
Old 08-13-2008 | 08:16 AM
KAAMA's Avatar
Originally Posted by Wild Card 09
In my opinion, one of the speed bringing aspects of a box, is that the c.of g. is moved rearward, whilst the drive acts like a third leg stabilising the boat as the hull start to air out.
Before I added the IMCO -2" shorties, my boat seemed a little too stern heavy...not sure if it is because of the weight of the extension boxes or not, but it got to be a little unstable (chine walk) at about 80+mph and I needed the K-planes to stablize the boat. However, applying the K-planes killed the speed.
Once the IMCO -2" shorties were added it gave the boat a different angle of attack or angle of trim and it made the boat sit on top of the water much better---and seemed to have changed the center of gravity so to speak. The ride and handling is a night and day difference.
The propshaft nut centerline sits about 1.5-2" below the boat now so, she throws a little bit of a rooster tail. www.youtube.com/watch?v=Ewc98ti5gN0
KAAMA is offline
Old 08-13-2008 | 11:15 AM
Wild Card 09's Avatar
the Flightmaster
There are so few general rules about boxes, drives and props, and even those have exceptions. My boat ran more stable over crosswakes with the standard drive and 4 blades than it does with the 2" shorty and 5 blades, but it is a trade off against other qualities.
My propshaft is now at 2 1/2" below the pad bottom.
The way the boat will fly straight and level in heavy chop is just amazing and the acceleration that the 5 blade delivers just pulls a smile every time!
Wild Card 09 is offline
Old 08-14-2008 | 12:41 PM
RBR - If you are out this weekend I will wave you down. I tried the same route as you by using the Stellings so I had the adjustability. The IMCO boxes with IMCO shorties are too bad, you can get shorties cases and install your bravo stuff. The Stellings, although adjustable are a BIG pain in the ass. it is way easier to fool with IMCO spacer plates. You can probably buy mine (IMCO Lowers) in a week... I am putting the bravo lowers back on today.
Keith Atlanta is offline
Old 08-14-2008 | 07:12 PM
DirtyMoney's Avatar
I will be out probably on Sunday.
DirtyMoney is offline
Old 08-14-2008 | 11:52 PM
hammertime42's Avatar
hammertime42
Tried all kinds of set up's with a 1995 35 fountain went with Imco nutral boxes so you dont move the motor or tail pipe angle or all kinds of other stuff [hatch height] raising your center of gravity all this costs .Then go with Imco drives with the raised cavitation plates you can then go with 3 inch shorties. Imco drives are 3 piece you can change the middle section to [or order them with] a raised cavtation plate. this will keep you from having to change your engine compartment. Never had any problems 750 hp + 102 mph handled great with 12 inch set back. I wen't to a new boat if you need Imco's with raised cavtation plates or just the mids I mat be able to help. Good luck.
hammertime42 is offline
Old 08-22-2008 | 09:47 PM
Stellings are crap! you lose the drive coupler and inherit a load of broken XR drive issues. Get out the checkbook $$
fossil fuel is offline
Old 08-22-2008 | 11:08 PM
KAAMA's Avatar
That may be so for some people, but for me I have had the Stellings boxes for 7 years or so and no broken/busted drives. Perhaps it's because of my mild powered naturally aspirated 565cid engines (about 670lbs of torque) and/or how I drive the boat---I don't think I have been too hard on the drives in how I operate the boat.
KAAMA is offline
Old 08-28-2008 | 05:11 PM
RBR - I took the boxes off. You want first oppty to buy them?
Old 08-28-2008 | 05:12 PM
$hit - I meant the IMCO lowers. Do you want them?
