#6 SS nose cone removal
I need to remove the SS nose cone on my 6's to access the aluminum housing in front of the gear case, but I don't have the cone shaped Merc tool used for this. Any suggestions on how to remove the SS cone using "standard" tools: without damaging the cone?
I called Cola, but he's not returning calls. Thanks |
Get the right tools - I tried using drift pins, etc... with no luck. You also need to heat the case where the threads are to release the loctite.
I could dig up the part #'s for the tools if you need .... |
The tool part numbers might be helpful: if I can afford the tools :eek:.
Thanks for the help. John |
My cost was just over $250 -
OK, I can handle that.
Thanks! |
John, Call Vern Gilbert at 310 995-1670 for any tips. He's a great guy and knows these drives. Tell him hello from me. Good luck. Doug
Socket tool is 91-847468
and the pin is 91-847418 Good luck Jon |
Those 2 parts on mercruiserparts.com came out to $150 plus shipping.
| All times are GMT -5. The time now is 03:13 PM. |
