-   -   Outdrive Lube (https://www.offshoreonly.com/forums/drives-lower-units/192933-outdrive-lube.html)
boatman22 08-10-2008 08:29 AM
Outdrive Lube
What is better for oil weight for Bravo 1's 75w90w or 75w140w. I'm changing to Mobil 1 gear lube.
offshoredrillin 08-10-2008 08:54 AM
I've always used merc and never had a problem, i do run mobil 1 v twin in the motors.
boatman22 08-10-2008 09:34 AM
I use v-twin in the motors also. Just wondering if the 140w would be better than the 90w lube.
Smitty 08-16-2008 09:22 AM
I run 85w140 Royal Purple in my XR's with big power.
