Should I worry?????? >
Old 09-21-2008 | 07:22 AM
BillR's Avatar
OSO Moderator
Default Should I worry??????
I just changed the oil on this drive that has 25 hours on it.
It blew up last August, and was rebuilt by a friend. That rebuild last 30 minutes. Got rebuilt by Joey Griffin in NC. Has been run 25 hours at mostly 3500 rpms. This is first oil change. I am thinking (hoping) the fuzz and chunks are leftovers from the 2 previous times it blew up and/or it is from break in.
Joey Griffin put in new gears, upper drive shaft, bearings and not sure what else.
I'll check the oil after a run or two, but an interested in the collective wisdom here - should I be worried?
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-21-2008 | 07:30 AM
Nope actually its quite normal considering it has new gears.
With new gears you will get a small amount of metal fuzz and as its used over time just a normal thing. Just make sure its not huge amounts or chunks.
prosno is offline
Old 09-21-2008 | 07:34 AM
BillR's Avatar
OSO Moderator
There were chunks in there.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-21-2008 | 08:13 AM
okay so I guess the question is what do you consider a chunk? how big? any pics?
I would say you might find small debris, nothing that big though
prosno is offline
Old 09-21-2008 | 09:41 AM
That looks like one of mine did this spring.
It had a pinion gear and the lower gear ( in the upper)
chunking out.
I'd be tearing it apart.
JaayTeee is offline
Old 09-21-2008 | 09:51 AM
Smitty's Avatar
I'm with JT. Take it apart and inspect it. If nothing wrong, no problem. If something IS WRONG, then you catch it now, not later at the expense of more gears, bearings, etc.
Smitty is offline
Old 09-21-2008 | 11:43 AM
That is not just fuzz. I would take it apart.
Griff is offline
Old 09-22-2008 | 09:31 AM
I had one like that last fall, tore it down and the pinion nut had backed off, somethings not right.
RonS is offline
Old 09-22-2008 | 05:56 PM
Mr Gadgets's Avatar
Charter Member #601
Bill,
If you can feel any chunks, Take It Apart!! It will be far better to find it now than later!
The fuzz on a magnet from new gears should be like pencil lead and no more. Any flakes or chunks and gears are coming apart..
Hope this helps.
Dick
Mr Gadgets is offline
Freeryd
06-26-2006 09:46 PM
