Bellows , Gimbal help >
Old 12-22-2008 | 02:51 PM
seafordguy's Avatar
Originally Posted by cocktails
Another question to add to this thread and stir the ideas alittle more. I have always had a wet bilge for years. I have changed out and replaced the bellows and shift cable bellows on both sides and still get a good amount of water into the bilge. I could have a perfectly dry bilge, put the plug in and back the boat down the launch ramp. By the time I unhook the boat and walk back with the hatch up i can actuall see an 1" to 2" of water already in the bilge. A merc. mechanic friend said it could be the upper seal that is around the vertical pin that the gimball ring is attached by the steering arm not sure what seal he is talking about. Any ideas and comments
Often referred to as the swivel seal.
You have two options - take the engines out, transom assemblies off and fix them that way, or you can do this method - http://www.jrmarine.com/instructions.htm
Mine are leaking so I am pulling my engines in the Spring to fix.
seafordguy is offline
Old 07-18-2009 | 01:53 PM
Default Quick Bellows Question
My buddy has his boat at a shop that says they have to pull the gimbal ring to replace bellows on a Bravo drive. I never did that. Is that correct or are they just moving stuff out of the way for nothing?
salesdeity is offline
Old 07-18-2009 | 08:59 PM
offthefront's Avatar
If they are just replacing the Bellows .... your buddy's getting a Lube Job .......
offthefront is offline
Old 07-18-2009 | 10:13 PM
HAHAHAHAA,,,,i think they are moving money in there pockets.
max an hour job each drive to change the bellows.
DareDevil is offline
Old 07-19-2009 | 09:15 AM
they're doing the gimbal bearing and bellows. does that mean they're still moving the gimbal ring for no reason and lubing him up?
Old 07-19-2009 | 09:21 AM
YEP,,,thats what it still means !!
bearing ( 10 mon. with the right tool ), after the drive is off.
Old 07-19-2009 | 10:05 AM
reguardless of how good it looks...why reuse bellows?? new ones are cheap insurance.
phragle is offline
seafordguy
2
06-20-2008 07:15 AM
MDGperformance
Drives and Lower Units
10
12-24-2007 07:59 AM
boatnt
2
10-19-2007 09:37 AM
cig1988
0
05-15-2007 03:54 AM
glassdave
3
04-29-2003 05:36 PM
