Bravo 1 to X/XR swap >
Old 01-02-2009 | 06:19 AM
Default Bravo 1 to X/XR swap
I need to tap into the infinite wisdom of the board!
Are the X and XR bolt in replacements for the Bravo 1?
If I were to break a Bravo 1 would there be any problem running an X or XR on one side and a 1 on the other?
Thanks.
Screamineagle is offline
Old 01-02-2009 | 08:54 AM
JasonSmith's Avatar
They all interchange. You can run a standard bravo with a xr, or an x. Not that it is a permanent solution, but if you had xr's & broke one & had a x for a spare or a standard bravo you could run that drive while your broken drive was being fixed.
JasonSmith is offline
Old 01-02-2009 | 09:22 AM
t500hps's Avatar
21 and 42 footers
While your example is correct, you can't just put an XR in place of a regular bravo. The Gimbal bearing is different for the XR. You can swap that bearing in the regular bravo transom assembly then run any of the 3 drives but the XR won't fit until that bearing has been changed. There is a "kit" but that bearing is really the only thing you must change.
t500hps is offline
Old 01-02-2009 | 09:38 AM
JasonSmith's Avatar
You are right. I always forget about the stupid bearing. I need to replace mine since I'm thinking about it.
Old 01-02-2009 | 09:43 AM
Also ,,,if u run a standart gimbal,,,i would change it to HP gimbal .
The HP gimbal has a stronger gimbalring.
Not that u need to change it to fit the XR,,,,but its worth it !!!!
DareDevil is offline
Old 01-02-2009 | 04:42 PM
All good info !
ezstriper
Prop Talk
3
12-09-2008 08:44 PM
torian
09-07-2007 11:08 AM
RollWithIt
16
08-25-2006 05:51 PM
jtybt15
08-25-2005 08:41 PM
21_senza_383_2
6
07-19-2002 02:57 PM
